DB level for single exhaust?
Old Apr 23, 2004 | 06:28 AM
wannabuy's Avatar
Default DB level for single exhaust?
I am looking to see if anyone has measured the level of any single exhaust systems. I am looking for the at idle, a parked rev to 6k, wide open throttle in cabin, and an in cabin 60-70mph. Anyone? I don't think anyone has but if I have an average DB level that I could have some data to work with. I am paticular looking for the Spugen Single TI.
Old Apr 23, 2004 | 07:59 PM
RazorV3's Avatar
amuse single r1:
idle : 74.9 db
cruising @ 3-4k rpm : 99.5 db
WOT: 114.8 db
Old Apr 23, 2004 | 08:07 PM
S2000RAT's Avatar
Apexi N-1 To loud when on the gas. Idle is cool.
RAT
Old Apr 23, 2004 | 11:41 PM
Rusler Firbrand's Avatar
in general, what would u think the average, idle noise, cruising, and WOT db be?
maybe an average of the members here can answer.
Old Apr 24, 2004 | 12:12 AM
JL9000's Avatar
T1R @ 4500RPM with test pipe:
silencer on: 82db
silencer off: 105db
Old Apr 24, 2004 | 05:22 AM
ImportSport's Avatar
I can take some measures from Dark_Sub_Rosa's Spugen single if you would like.
One thing to take into consideration is that the provided levels as measured are most likely ambient noise level A weighted dB SPL. If your concerned about your hearing then you need to take into consideration SPL levels at the eardrum which are distinctly different that these technically free-field measures.
Old Apr 24, 2004 | 11:14 AM
Ludedude's Avatar
Administrator
What are the test conditions that all these sound measurements were made? Unless they're nearly identical the comparisons are not too helpful.
Old Apr 24, 2004 | 06:14 PM
wannabuy's Avatar
The police is the question. They have a microphone that measures the sound level when the vehicle is passing the officer. The distance is ? I forget. My Civic is at 105 including the noise floor. The sound of the car if over the ambient noise shoudl give a decent result as long as you are about 10ft from the object. Hearing and testing never come out the same. I am really just looking at peak levels. Thanks for the input so far. Anyone have the spugen single ti??
mikefifth
Feb 3, 2014 11:49 AM
MDS2KAp1
Jan 9, 2007 06:45 PM
topcat7111
Jan 24, 2006 12:51 PM
owenxguo
Jul 19, 2004 06:09 AM
PedalFaster
Jul 10, 2003 10:39 AM
