Diagnosing an exhaust leak?
Old Sep 12, 2005 | 08:54 AM
Shift_S2K's Avatar
Thumbs up Diagnosing an exhaust leak?
How do you diagnose an exhaust leak? I had the Mugen Header installed last Friday and can't tell if I'm just hearing the gasses flowing through it or if it has a leak.
It seems like I'm hearing a slight hiss but that could just be paranoia...
Having had an exhaust crack on me before I would assume that a leak from the header would be much louder than a hiss but I'd still like to be sure.
How exactly do you check a header for leaks? Soapy water comes to mind but that seems like a bad idea...
On the bright side, the power gain from the header is quite nice
Thanks
Old Sep 12, 2005 | 09:54 AM
xviper's Avatar
Soapy water is a bad idea for something that gets so hot. Do you smoke? Blow cigarette smoke over the area. If you have a leak, you'll see a disruption in the smoke pattern. Make sure you rad fans are not on.
S2SICC
Oct 9, 2013 08:34 PM
pinoyk20
Nov 4, 2008 08:39 PM
s2kv
Feb 10, 2006 06:27 AM
REVZ TO9
Jan 20, 2006 04:50 PM
HeNeSSeY
Mar 28, 2002 02:46 PM
