did a compression check
Old Feb 12, 2011 | 03:23 PM
josh7owens's Avatar
Default did a compression check
all the cylinders were between 200-205. The car has 130k on it. I'm happy they are all around the same but isn't that alittle low?
Old Feb 12, 2011 | 03:54 PM
s2cho's Avatar
should be higher.... around 250's
but your altitude and temp can affect the numbers,
so if there all around the same i think it you should be good
Old Feb 12, 2011 | 03:59 PM
eehandee's Avatar
Good numbers, you don't have to worry about the numbers as long as they're consistent. I believe anything within 5% of a variable is fine.
6gearpower
Feb 22, 2013 10:41 AM
cdelena
Apr 30, 2006 08:42 PM
ADAM_ROB_UK
Sep 19, 2005 02:09 AM
