Did I "blow" my engine mount?
Old Oct 18, 2002 | 10:18 AM
SaV's Avatar
SaV
Default Did I "blow" my engine mount?
After some canyon carving last night, I woke up in the morning to notice that there is a leak under my engine. It is oily, clear oil, not like dirty engine oil. Upon closer inspection it is coming from the left moter mount that is under the exhaust manifold. Is our moter mounts "liquid" filled, like the differential mounts? Also, should I be alarmed by something like this? I really don't want to fix it if I really don't have to. Thanks!
Old Oct 18, 2002 | 01:37 PM
xviper's Avatar
I don't think there is any fluid in those mounts. The oil filter is very close to that area. Have you checked to see if it is loose? There may also be a brake line near there. Check your brake fluid reservoir to see if the level has dropped dramatically.
Are you sure it's oily substance and just water from your A/C condensor drain line?
Old Oct 18, 2002 | 10:16 PM
SaV's Avatar
SaV
I have a Injen CAI, so I can see the top of the mount clearly. There is indeed fluid coming from the mount (like cooking oil). It couldn't be my brakes because I have ATE SuperBlue. It also couldn't be my oil because it is quite dirty and due for an oil change. Would there be any reprecusions if I were to leave it alone? Damn . . .
Old Oct 19, 2002 | 03:30 AM
Austin_S2000's Avatar
It is quite possible it is liquid from the motor mount.
My rear differential mount leaked oil and had to be replaced early on. I had no clue that they used some type of oily substance in these mounts until this happened.
Old Oct 19, 2002 | 05:10 AM
cthree's Avatar
Administrator
Sounds like you need a trip to the dealer.
Old Oct 19, 2002 | 08:41 AM
SaV's Avatar
SaV
[QUOTE]Originally posted by Austin_S2000
[B]It is quite possible it is liquid from the motor mount.
Old Oct 19, 2002 | 11:16 AM
The Unabageler's Avatar
u have to remove the engine subframe to do that, or lift the engine up from it a good bit which would require disconnecting a shitload of stuff. hope u got a lift
Old Oct 19, 2002 | 11:35 AM
SaV's Avatar
SaV
[QUOTE]Originally posted by The Unabageler
[B]u have to remove the engine subframe to do that, or lift the engine up from it a good bit which would require disconnecting a shitload of stuff.
mhansen146
Feb 15, 2014 05:21 PM
dogzilla
May 30, 2013 11:39 AM
trustafox
Jan 20, 2012 03:05 PM
street_ruler
Jan 27, 2011 10:28 AM
Spec_Ops2087
Mar 25, 2006 05:36 PM
