Diff Clicks?
Old Jun 10, 2007 | 05:59 PM
ScrapeApe's Avatar
Default Diff Clicks?
There is a clicking sound that comes from the rear of my s2k when leaving (2k rpm) a complete stop. It clicks 1, 2, sometimes 3 times and seems to be more prevalent when on inclines and when warmed up? Any ideas?
Old Jun 11, 2007 | 01:30 AM
photown's Avatar
I think it is the rear Hub nut that is causing the problem. To fix the problem, you should get 2 new Hub nuts and torque them down to 220 ft lbs of torque.
Old Jun 13, 2007 | 01:06 AM
JDM613's Avatar
i have this problem to, i have replaced both read hub nuts, and torqued both to the spec in the sticky about this problem, i gave up on the problem for the time being, it has been clicking since i owned the car. but it has not gotten worse, and nothing seems to be suffering.
Old Jun 13, 2007 | 01:18 AM
FISH22's Avatar
before considering the diff...like stated above, make sure the axle nuts are torqued down properly, if they are. move on to the axles. also, if it is the axle nuts, and its been doing this for some time, there could have already been enough damage done to the bearing/hub. only fix for that is replacement, but first, check the torques come back with what you discover.
Old Jun 13, 2007 | 05:04 AM
tinkfist's Avatar
No need for new nuts. Re-use the old ones
MrWant
Feb 19, 2012 09:23 AM
hypforlife32
May 1, 2010 05:33 PM
esmith51
Jul 21, 2009 10:08 AM
thorax
May 8, 2007 08:17 AM
Eugeneo
Oct 15, 2005 11:59 AM
