Diff failure question
Old May 23, 2010 | 03:08 PM
nartnailuj's Avatar
Default Diff failure question
I been considering doing a Final drive upgrade. My car is a daily driver with occasional aggressive driving but never any launching. No track/autocross, no drag strips but occasional harmless races with friends. My question is that do i need a reinforced diff housing from CT? Im not planning on boosting either. I heard the s2000 diff is a weak link. Is it the diff or the diff housing? if the diff is a weak link then the reinforced diff housing wont make a difference? Pretty much i dont want to invest in a final drive upgrade and blow my diff. what can i do to prevent that? I was thinking 4.77+CT reinforced housing (if the housing is the weak link), but if the diff is the actually weak point, how would i go about preventing my differential from failing?
Thank you
Old May 23, 2010 | 03:13 PM
nartnailuj's Avatar
If the housing is the weak point, can i solve the problem by buying the CT enforced diff housing for my final drive project?
If so, i am planning to buy the final drive, install kit from HTG, enforced housing from CT, and other seals and ect for the shop to install. is that all i need to put everything into the CT housing?
Old May 23, 2010 | 06:54 PM
ronnuke's Avatar
The weak point is the bearing caps and bolts that hold them along with the crush collar distance piece. The bearing caps give under shock loads causing misalignment of the pinion which then grenades your diff...as best as I can determine. The crush collar allows for further deformation allowing the torque on the backlash nut to go awry further aggravating the problem. All these issues are fixed with the Puddy modded diff.
PM Puddydad for more info.
Old May 23, 2010 | 07:20 PM
nartnailuj's Avatar
I'm going to do some further research on the reinforced housing and see if its designed to protect the bearing caps from coming apart. If it does, im going to buy it.
Old May 24, 2010 | 01:00 AM
SpitfireS's Avatar
ronnuke Posted on May 24 2010, 03:54 AM
The crush collar IS NOT a weak point at all.
In any way or form.
If you think it is you don't know how it works
IMO, some oils are.
Old May 24, 2010 | 01:15 AM
nartnailuj's Avatar
what do you mean some oils are??
Old May 24, 2010 | 01:33 AM
SOHCmyDOHC's Avatar
As long as you don't do 6k+ rpm clutch dumps from a dead stop your diff should be fine.
A properly set up diff should hold up to the abuse you describe as your driving style.
Also, please keep your "harmless" races away from inhabited roads/streets. Harmless races usually end up the worst. Save some $$ and take it to the track where you can learn the potential of you and your car in a safe environment.
Old May 24, 2010 | 12:20 PM
nartnailuj's Avatar
yeah thats what i was plannin to do but i couldnt find any classes to take in sacramento. Do you know of any?
by the way, thanks for helping me out with all my questions. I noticed that you answered every single one of mine. I appreciate that
Old May 24, 2010 | 09:05 PM
SOHCmyDOHC's Avatar
Classes? HPDE or autoX? Check out the stickies in the sac forum for our autoX thread. You'll see us there and its close to you since it's at Mather Airfield.
Old May 25, 2010 | 12:46 AM
B serious's Avatar
I launched my car all damn day on Sunday at like 8k RPM with a Hyper single clutch and 265/40R17 Z1 star specs at an autocross. I was slipping the clutch...but still.
Diff seems fine. This isn't the first autocross/donut/45second long burnout/drag strip/HPDE/gear slam the car's ever had either. The car has 37k miles on it now.
I know it'll break eventually. Hopefully not at a HPDE. Besides that, I really don't care if it does or doesn't break.
