Diff failure question
Originally Posted by B serious,May 25 2010, 01:46 AM
I launched my car all damn day on Sunday at like 8k RPM with a Hyper single clutch and 265/40R17 Z1 star specs at an autocross. I was slipping the clutch...but still.
Diff seems fine. This isn't the first autocross/donut/45second long burnout/drag strip/HPDE/gear slam the car's ever had either. The car has 37k miles on it now.
I know it'll break eventually. Hopefully not at a HPDE. Besides that, I really don't care if it does or doesn't break.
Originally Posted by SpitfireS,May 24 2010, 04:00 AM
ronnuke Posted on May 24 2010, 03:54 AM
The crush collar IS NOT a weak point at all.
In any way or form.
If you think it is you don't know how it works
IMO, some oils are.
In any way or form.
IMO, some oils are.
ronnuke Posted on May 25 2010, 02:01 PM
There's nothing wrong with the design.
You do need to follow the install instructions though.
No.
When in reverse, the small pinion bearing takes the load.
During engine braking the small pinion bearing takes the load.
There is no load on the crush sleeve at any time after assembly.
Because people go cheap and don't use a new nut.
Or they tighten it too far because they used big steps - and crush the sleeve too far - and then have to loosen it to get the right pre-load on the pinion bearings.
Play in the pinion changes the pinion depth, not backlash.
In reverse or during shifts, when the pinion is drawn into the ring, it goes BOOM.
Backlash is set by moving the ring sideways.
There is no extra deformation on a correctly installed crush sleeve.
A new locking nut will not loosen.
The main downside of a solid distance piece is that one has to be VERY precise in shimming it to the desired lenght to get the proper pre-load on the pinion bearings.
Once the distance piece is shimmed-to-lenght correctly one can tighten the nut tighter than with a crush sleeve, that is true.
But what's the purpose?
There is no load on the nut.
Anyway...
nartnailuj Posted on May 24 2010, 10:15 AM
Well...
The pinion of a hypoid gear set wants to push the ring away from itself (when driving forwards)
The higher the offset of a hypoid gear set the more this happens.
Offset = the distance between the centerline of the ring and the centerline of the pinion.
The S2k hypoid gear set has a pretty high offset and there is a lot of sliding going on generating forces that "push the ring out the back"
That's why Honda recommended SAE 90 GL-5 or GL-6 in the early MY manuals (maybe they still do) as GL-6 was intended to be used in high offset hypoid gears.
The API GL-6 spec never became official though.
And... SAE changed the spec.
IMO, modern multigrade xxW-90 gear oils are lighter and not as "strong" (= have Extreme Pressure capabilities) as the SAE 90 GL-5/6 mentioned in the early year manuals.
Just my opinion though.
the crush collar design is flawed
in that it will allow further deformation when put under shock load in the transverse direction
allow the preload nut to back off
play in the pinion which is detrimental to proper backlash setting causing pinion damage
Solid machined distance piece will alleviate the possibility of this deformation and loosening of pinion preload nut.
Anyway...
what do you mean some oils are??
http://www.hardtopguy.com/store/product.ph...52&cat=0&page=1
instead of using Mobil 1 Synthetic Gear Lube LS 75W-90 because its not "stronger"?
