diff. fluid
Old Jan 29, 2009 | 05:34 PM
tlee1234's Avatar
LE 607, best
Old Jan 29, 2009 | 05:39 PM
s2kVTAK's Avatar
i used lucas oil 75W/90 if NHRA can use it with sucess then it should be good for the S.
Old Jan 29, 2009 | 06:25 PM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
Amsoil 75-140 GL-5
Old Jan 29, 2009 | 06:35 PM
iDomN8U's Avatar
They dump the oil and use something else to get the sponsership.
Old Jan 29, 2009 | 09:05 PM
Saki GT's Avatar
I've always used Mobil 1 - no issues so far.
Old Jan 30, 2009 | 07:18 AM
PJCC's Avatar
Originally Posted by iDomN8U' date='Jan 29 2009, 05:53 PM
buy this, one of the best products on the market for our diff.
http://www.hardtopguy.com/store/prod...?productid=252
Old Jan 30, 2009 | 10:18 AM
rossco's Avatar
i am using some jdm tomei synthetic rear differential gear oil gl5. 75w-90w. honda recommends any
compatible gl-5 classified gear oil usually about 75w-90w. synthetic or not.
with original fluid from factory had noise from the rear diff when taking sharp turns, after putting the tomei diff fluid noise is gone. seems a lot smoother.expensive though.
Old Jan 30, 2009 | 10:27 AM
silvery2ks2k's Avatar
ive been usin royale purple with no problems i think its really a matter of opinion everything works fine no matter what fluid you use just depends on the type of driving you do and what wheight fluid it is.
Old Jan 30, 2009 | 11:08 AM
s2k_ed's Avatar
i have royal purple in mine right now but im going to try amsoil next.
Old Jan 30, 2009 | 12:39 PM
vincewchan's Avatar
I use Motul Gear300 75W90.. it's like $10 a qt and you only need a little under a qt.
