diff fluid on diff.. pic and question
Old Aug 20, 2006 | 05:00 PM
rijowysock's Avatar
Red face diff fluid on diff.. pic and question
had diff fluid swapped at 30k
car at 40k
no abrasion on diff to show it touched anything ro anything touched it.seal in tact not leaking... drain and fill bolts fine.
seems like 2 bolts on bottom might be leakin... put instant gasket on it.. to see if thats it will check again daily..
riley
usual?
unusual?
go to honda and get diff fluid changed and have them look at same time?
Old Aug 20, 2006 | 05:17 PM
rijowysock's Avatar
diff fluid was changed at 30 when i bought no receipt tho maybe wrong fluid?
whats correct honda fluid for when i go
or should i just bu the amosol from hardtoguy
http://www.hardtopguy.com/store/product.ph...2&cat=56&page=1
Old Aug 20, 2006 | 06:11 PM
gomarlins3's Avatar
^That's what I use. Tell us if the fluid comes back.
Old Aug 20, 2006 | 07:34 PM
xviper's Avatar
There is no correct Honda fluid for this diff, at least with the car division. The only "Honda" diff fluid that will work on this car is from their motorcycle division.
Old Aug 20, 2006 | 11:44 PM
SpitfireS's Avatar
Or the "Honda" Marine SAE 90 GL-5 hypoid oil.
(I just have to say it.... )
Could that leaking oil come from the oil filled mounting dampers?
(The picture doesn't work.. just guessing)
Old Aug 21, 2006 | 06:19 AM
rijowysock's Avatar
oil filled mounting damper?
explain
Old Aug 21, 2006 | 06:22 AM
rijowysock's Avatar
if their is no correct honda fluid then what do they use when i go in for diff fluid flush
Old Aug 21, 2006 | 06:39 AM
stitos2k's Avatar
That's always the question, if you don't ask you just simply don't know.
If it makes you feel any better, if they'd used the crap they put in most honda cars, your diff would be dead already.
Old Aug 21, 2006 | 06:50 AM
rijowysock's Avatar
called honda.. he said come in,
their gon check/change diff fluid and oil
since everyone says they dont have the right diff fluid can i buy at local autozone? or similar and what to buy
Old Aug 21, 2006 | 06:53 AM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
Use 75 W 90 GL 5 gear oil.
I use Redline,a lot of people use Mobil 1.
