which diff mount to go with?
I am a street driver, not going on the track other than the occasional day. I have an 04 and it's stock...
I need a differential mount, the rt rear is leaking so I am thinking replace with the rubber/polyurethane type. A kit of 4 is about $160.00 on amazon.
Question #1 anyone have any experience with aftermarket differential mounts?
Question #2, whose do you recommend?
Question #3 I am thinking they have rating in terms of stiffness....they start at 60, then go to 75, WHATEVER that means, anyone have any idea of which one to buy to have a stock controlled ride??
Thanks
Thanks
If the rest of the car is stock I would stick with OEM. Any aftermarket mount is going to introduce more vibrations even their softest rated ones and there really isn't any point on a car thats otherwise stock. I have a set of Spoon diff mounts that are slightly stiffer than OEM but even those cost a good deal more than the OEM mounts.
Perhaps the mounts that produce the most NVH when going poly are the diff mounts. You'll hate them on a street car.
Go rubber, preferably with oem.
If you want better responsiveness yet still retain most of the oem smoothness, get diff collars (and new rubber mounts, preferably oem). They work surprisingly well.
agreed w this, i've got the hasport poly diff mounts too, with an osgiken. no additional nvh at least that i can notice over the exhaust
Good to know. I am going to be installing Hasport hardened rubber mounts, but if the poly diff mounts don't add any NVH, I might as well go to that. As it is, my diff is vibrating under acceleration so I don't know how much more NVH can be added with new mounts.
"No NVH that I can notice over my exhaust" should probably be the takeaway for you.
The typical S2000 aftermarket exhaust is like riding inside of a jackhammer. So...yeah, you may not notice a damn other thing.
Maybe someone with a stock exhaust a poly mounts can chime in. That may be a more valuable data point.
There's a reason the car didn't come with poly mounts. Likely NVH being the leading reason.
Previously, everyone that tried poly diff mounts for street hated them. Reported horrible vibes. Obviously tastes and tolerances differ. But it was mostly universal condemnation.
I'd do more research if was contemplating them.
Hasport sells hardened rubber nowadays? Or did you mean Hardrace?
I couldn't find any videos to show how different they perform. I'm mostly autocross in my s2000.
darcy
