diff is out
Old Mar 18, 2007 | 06:24 PM
YCOWY's Avatar
Default diff is out
so i got off the interstate the other day and heard a weird noise from my cars rear, listened to it a little more on the way home and decided not to drive it for a couple days, took it to a mechanic who has an ap1 also and we did the diff tests, the left wheel is bad. i havent gotten back to him yet on the results of taking it apart but im opening my options now as to new diffs, any reccomendations?
Old Mar 18, 2007 | 06:26 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
"Left wheel is bad"....you'll have to explain what you found.
Old Mar 18, 2007 | 06:45 PM
YCOWY's Avatar
the right wheel would spin freely in neutral, the left would only spin with a considerable amount of force applied to it. We put the car in gear and the right wheel had no problem, but it took some throttle to get the left moving.
Old Mar 19, 2007 | 02:31 AM
SpitfireS's Avatar
Are you sure the brake pads weren't sticking a bit?
Diff test should be done in gear, engine off, rear wheels off the ground, turn one wheel - the other should turn opposite.
Drain the oil.
Watch for shavings on the plug and/or bigger chuncks in the oil.
What oil was in there and when was it last changed?
Old Mar 19, 2007 | 01:31 PM
jyeung528's Avatar
even if you were to consider other diffs...what other options do we have for the S?
Jerry_Attric
Oct 2, 2015 06:14 AM
PiSoft
Feb 16, 2015 05:04 AM
wrightbenz
Aug 27, 2011 09:26 PM
GrittyShaker
Mar 28, 2010 11:22 AM
