diff problem
Old Mar 22, 2007 | 09:19 PM
s2kboii's Avatar
Default diff problem
hey does anyone can shine some light on how to take the axels off the differential on ap1? because i tried to search and look in DIY section but it doesn't say..and i tried using pivot ball joint remover on axels to spread them but i couldn't get it far enough to make the axles pop out of the diff. so if anyone can shine some light on this i'd appreciated it very much!
Old Mar 23, 2007 | 01:27 AM
SpitfireS's Avatar
s2kboii Posted on Mar 23 2007, 06:19 AM
....but i couldn't get it far enough to make the axles pop out of the diff.
You mean: pop the axle out of the output shaft right?
You can't take the complete axle (with output shaft) out at once.
The output shafts stay in the diff.
You'll have to remove the bolts that hold part #5 to the rest first.
And remove the ABS wire bracket from the suspension arm.
That may have kept the hub from going out far enough.
Succes.
Old Mar 24, 2007 | 01:31 AM
s2kboii's Avatar
Success! Thanks for the input!
S-Turn AP1
Jul 27, 2008 10:17 AM
nightcrawler7188
May 28, 2008 02:01 PM
FCBrandon
May 6, 2007 10:32 AM
esracer
Mar 2, 2005 10:41 AM
