Difference in AP1 and AP2 Fuel Rails!
Old Nov 18, 2007 | 10:54 AM
syellow's Avatar
Default Difference in AP1 and AP2 Fuel Rails!
I need a fuel rail.... Found one of an ap1. Will these fit and 04 ap2? I need it to tap my fuel pressure gauge. I want to save my stock one. Thanks
Old Nov 26, 2007 | 01:53 PM
syellow's Avatar
While installing my turbo, I decided to go with the AEM fuel pressure regulator. This does not have a port on it for a fuel pressure gauge. Therefore, I had to tap the fuel rail for the gauge. Having never used a tap and die set, I ordered an oem fuel rail in case i messed up. I was told on the forums that they were identical. However they are not. The AP2's have a brace bolted to them where the fuel inlet bango bolt is as the AP1's don't. However I was able to put a crush washer on the AP1 fuel rail and it worked fine. So there is a difference between the fuel rails, but you can make them work.
Old Nov 27, 2007 | 06:53 PM
NVMY4N's Avatar
Merged threads. Just bump and edit your old thread instead of clicking it would be different if they had nothing to do with one another.
rtboy10
Sep 1, 2013 04:59 AM
Princeneo
Jan 20, 2012 04:33 PM
Akblues2k
Oct 3, 2011 03:58 AM
TerminatioN
Oct 5, 2010 12:41 PM
Kermdaddy
May 7, 2008 07:30 PM
