Difference between 00-01/02-03 ecu?
Old Dec 3, 2008 | 10:47 PM
aw11's Avatar
Default Difference between 00-01/02-03 ecu?
Just wondering why the 02-03 ecu is said to be better.
Old Dec 4, 2008 | 12:22 AM
ahrmike's Avatar
different fuel map.
o2-03 gets better gas mileage, more powa.
Old Dec 4, 2008 | 06:09 AM
pdenton's Avatar
yay for not searching *wink* how hard is it to do said ecu swap?
Old Dec 4, 2008 | 06:22 AM
SgtB's Avatar
You need the new ecu's vin and your vin. Go to the dealer, plug in the new ecu and then ask them to reprogram the new ecu to your keys. Done.
Old Dec 4, 2008 | 07:17 AM
HankookS2K's Avatar
00/01 ran richer
02/03 is more lean
Old Dec 4, 2008 | 12:00 PM
vtec9's Avatar
^ what he said.. they leaned out the fuel mixture a bit which gives a handful of extra ponies.
Old Dec 4, 2008 | 03:16 PM
blkwidow's Avatar
Would you switch over if you were going FI? Or would the extra fuel help keep knock in check, and or possibly better to fine tune.
Old Dec 4, 2008 | 03:45 PM
Slows2k's Avatar
The difference is so small I wouldn't bother swapping a functional PCM for another.
Old Dec 4, 2008 | 03:46 PM
pdenton's Avatar
So there's no "matching" required? I ask because my last car was a saab 9-5 which had different models with different options so you had to find an ECU with the same transmission, etc as you had. I assume since the s2k has no real options like that, any ECU will work? Also, is there any reason one wouldn't want to do this to their 00-01?
Old Dec 4, 2008 | 04:07 PM
HankookS2K's Avatar
no, if your going FI you should be using a stand alone anyways
