Difference between AP1 and AP2 I/H/E
Old Apr 10, 2007 | 12:16 PM
pixelharmony's Avatar
Default Difference between AP1 and AP2 I/H/E
I have a 2004 S2000 and I'm trying to get these parts back to stock and want to know if there's any difference in the parts (other than part #'s)
I need:
Stock Intake (Replace my AEM V2) - all tubes and clamps as well
Stock Header - Any difference from AP1 to AP2 (also do I need that heatshield?)
Stock Cat - Any difference?
Stock Exhuast - Any difference other than the tips?
Thanks guys!
Old Apr 10, 2007 | 12:19 PM
jyeung528's Avatar
i think it should all be the same.
www.hondaautomotiveparts.com
you can do your own homework if nobody knows for sure.
Old Apr 10, 2007 | 12:23 PM
I did look at that site actually.
They gave different part #'s for the headers, and the exhuast looks the same.. but I called honda and they have different part #'s as well.
Old Apr 10, 2007 | 12:39 PM
2004 - S2000
1312637 - MUFFLER SET, EX. - 359.98
204501 - CONVERTER - 536.40
1312783 - MANIFOLD, EX. - 512.11
1312951 - COVER A, EX. MANIFOLD - 131.93
2001 - S2000
204500 - MUFFLER SET, EX. - 359.98
205683 - MANIFOLD, EX. - 512.11
205685 - COVER A, EX. MANIFOLD - 131.93
Looks like just the converter is the same.
Old Apr 10, 2007 | 01:03 PM
S2KPUDDYDAD's Avatar
Check with your local S2K forum for the parts you need. Most of what you need can be had local for free or very close to free.
Your air-box. header, cat, and heat shield are all the same
Your Exhaust is a bit different because AP2 has a double hanger/hooks on each muffler and the muffler tailpipe extensions are a little longer for the newer style tips. You can still use an AP1 if you are in a pinch with just a little creativity
Old Apr 10, 2007 | 01:10 PM
beanolo's Avatar
You can use the AP1 exhaust... the car body is the same, it was the exhaust hangers and rubber pieces that were different.
So as long as you buy the AP2 exhaust WITH rubber pieces, OR the AP1 exhaust with the AP1 rubber pieces, you are good.
Old Apr 10, 2007 | 01:28 PM
Thanks a lot guys!
Old Apr 11, 2007 | 07:26 PM
iamhomin's Avatar
Pixel? You from Azine too right?
I never knew you owned a S!
rfsinopo
Jun 20, 2018 11:41 PM
jun11
Aug 11, 2017 08:15 AM
Sophotrope
Sep 12, 2016 11:25 AM
21337R
Sep 8, 2010 03:43 AM
dammitjim
Sep 29, 2009 04:56 AM
