Differences between AP2V2 radiator and previous generations.
Old Aug 5, 2015 | 08:45 AM
pandaboy50's Avatar
Default Differences between AP2V2 radiator and previous generations.
I tried installing a Mishimoto radiator and it did not go well. The water temp sensor did not fit and the fan shroud did not fit at all either.
Old Aug 5, 2015 | 09:18 AM
aphex4000's Avatar
The change in temperature sensors is not split between AP1 and AP2 models. Instead, I think the MY06+ temperature sensors are a bit smaller. You should have received an adapter with your Mishimoto radiator to fit the smaller sensor (mine came with one)
My AC compressor fan shroud (driver side) did not fit very well either. The alignment of the mount(s) were very poor. I carefully bent one of the mounts slightly, loosely lined up all the bolts, then tightened them down a little at a time.
Old Aug 5, 2015 | 09:20 AM
afzan's Avatar
^ what he said
Old Aug 5, 2015 | 09:47 AM
pandaboy50's Avatar
Hmm interesting, mine did not come with an adaptor nor did the fan shroud match up at on the driver side. The holes were about half an inch off.
Old Aug 5, 2015 | 09:51 AM
aphex4000's Avatar
That's about how far mine were off as well. Since there are three (instead of four) bolts, I honestly couldn't tell you which mounting point was the cause of the problem. I just bent one of the top ones a little and kinda just averaged out the error.
Contact Mishimoto about a replacement for the missing sensor adapter. Posts from other owners have indicated that they're quite responsive to requests related to leaky radiator caps, warranty claims, etc.
Old Aug 5, 2015 | 10:10 AM
pandaboy50's Avatar
Thanks, I called them and sent some pictures. They are going to call me back (soon) hopefully.
Louisq
Dec 29, 2015 05:36 AM
iAhmad
Aug 1, 2013 09:55 AM
crits2k
Apr 9, 2009 06:59 PM
mikitymike55
Dec 24, 2007 11:01 PM
spoiled@21
Nov 4, 2005 11:52 PM
