Differentail Fluid Help
xviper said, "Just don't let them (Honda Dealership) put in Honda diff fluid. They don't make a diff fluid for the S2000. Whatever they have is NOT for this car and may damage it. Ask "Incubus".
is this true??? i got my diff oil changed at my Honda dealership at about 2,000 miles ago. what should i do?
[QUOTE]Originally posted by s2k_9000rpm
[B]xviper said, "Just don't let them (Honda Dealership) put in Honda diff fluid. They don't make a diff fluid for the S2000. Whatever they have is NOT for this car and may damage it. Ask "Incubus".
I have replied by PM to the author but here is the thread in question:
https://www.s2ki.com/forums/showthread.php?...?threadid=99785
This person posted later stating that the dealer owned up and replaced the diff.
when the s2k was first out, dealers would always make the mistake of putting in the wrong fluid. but now(atleast at my dealership) since the s2k has been out for a while, they are using correct fluids. for instance, at my job, they use castrol hypoy c 80w90 gl5+ limited slip gear oil . jsut to be safe, call the parts department of that dealership and ask them what they sell for the s2k differential.
Check this thread out. https://www.s2ki.com/forums/showthread.php?...threadid=115704
Also this one https://www.s2ki.com/forums/showthread.php?...?threadid=75494
Based on the lab analysis I'm sure the Honda dealer put in the VTM stuff during my first differential change. Especially considering that the lab analysis from my third differential change Mobil 1 75W/90 showed little to no excessive wear.
Thank goodness I got the 7 year-75000 mile warranty and have some proof of differential wear following the dealer fluid change. I'm probably screwed, but at least if I have differential problems I can try and get it replaced.
i just got off the phone with my honda dealership and they said that they use 80-W90 for the S2000 differential. anyone know if this is okay to use? should i change it out as soon as possible?
