Differential Clunking Noise
Rest in pieces.
Good luck with your fix!
I doubt slicks, alone, caused that kind of damage. It looks like sudden shear forces. At least, that is my experience blowing out differentials. I've redone a couple BMW rear ends, which were subject to power-slides. On-again/off-again high torque moments. All done while racing.
OP: I reckon you should go with a Puddy built diff and run 75-140 as he recommends for those. If it's too pricey then your best bet is to get a good condition second hand OEM one. the AP2 '04 and up diffs have strengthened casings. Up to you which path you choose.
P.S. If the wrong fluid was run in the diff for an extended period of time before you bought it then chances are high that the RP 75-90 you used was not the culprit as the damage was done. In the end it's a sorry sight...
Slicks will increase shock load under launch conditions and so will a puck type clutch disc - too harsh in most cases.
In the future I guess I will just try to go a little easier on the sliding through corners but overall a few hundred bucks and alot of learning has left me even more intrigued to see what this car is capable of.
I found an 04 with low mileage for a steal. I have talked with Puddy and he is such an asset to the S2000 community. As soon as I can afford to I am going to send a diff his way to be overbuilt and hopefully grenade proof. What does the sludge indicate? I was assuming that was just very fine metal shavings and gear oil that stuck to the magnet.
I'm sure you'll find our cars are capable of quite a lot of goodness
