Differential fill bolt head is rounded off
As I try to remove the fill bolt on the differential the bolt on there is too tight and now my bolt headed are starting to round off and the 23mm wrench aren't having any grip on it anymore.
Any idea on how I can get this to remove I have the new bolt to replace it once the old come out after the fluid change? Checking Sears to see if they have a Craftsman Bolt out kit but the max size only goes up to 19mm .
A little advice, don't pull or push on the wrench when you're trying to loosen the bolt, instead give it a smack with the palm of your hand, the sudden shock usually loosens the bolt and you don't run the risk of rounding it.
This works with all bolts.
As for the OP and others with already rounded bolts, try vice-grips as mentioned above or hammer/chisel.
