Differential fill bolt head is rounded off
Old Mar 27, 2014 | 09:22 PM
  #21
Themikewoo's Avatar
Links for magnet?
Old Mar 28, 2014 | 03:25 PM
  #22
leemaverickly's Avatar
I have a question with the filler and drain washer/gasket. They seems to be the same size to me and are just with different material. Can I mix them too?
Originally Posted by freq
Originally Posted by s2000maniac' timestamp='1395949694' post='23084460
get magnetic bolt as its same size as the fill bolt. you can run dual magnets and it will pick up more debris and metal shavings!
Yup Yup!!!
Use a drain on the fill and the drain. "You win twice brother." -Joe Dirt
Old Mar 28, 2014 | 03:27 PM
  #23
I didn't know this website at all. Bookmarked. Thanks bro.
Originally Posted by dwight
90081-PCZ-003 021 001 PLUG, MAGNETIC 12.93 9.05
http://www.hondaautomotiveparts.com/...R+DIFFERENTIAL
It's the best solution, but if your local dealer tries to charge over list and you don't want to haggle with them, you can order from estore.honda.com and have the part shipped to the dealer for free and you just pick it up there.
Old Mar 31, 2014 | 10:42 AM
  #24
liybzd's Avatar
Just change my diff oil last weekend, I used a 7/8 crow foot wrench, which is about 22+mm, and I filed both sides to make it bit larger. It then works very well with regular wrench to get it off and then with torque wrench to the correct torque.
Old Jun 27, 2014 | 11:27 PM
  #25
subwayasian's Avatar
So let me get this straight guys, for the differential for the s2k, the FILL and DRAIN bolt have the same sized PITCH correct ?!
Old Jun 28, 2014 | 05:55 AM
  #26
dwight's Avatar
Correct. The drain and fill bolts are physically interchangeable. When I changed my fluid for the first time, the drain bolt was in the fill bolt's location and vice versa. They are now in the correct positions.
chubbys2k
Feb 22, 2016 07:11 PM
kap
Nov 13, 2015 01:17 PM
mxt_77
Jan 31, 2008 06:08 AM
Sugrray
Dec 28, 2004 05:21 PM
CaptinMorgan97
Oct 6, 2003 04:13 PM
