Differential Fun
Old Aug 30, 2001 | 06:58 AM
cjb80's Avatar
I have the opportunity to buy a new Kaaz Diff for around $700-800, and I was wondering if you guys think I should do it.. I don't REALLY have the money right now, but I think I can pull it off.. but it will make things tight on the budget later on..
Are there any alternatives that are better than Kaaz right now?? Also, does the Kaaz unit replace the stock final gear, or is that a seperate piece? Would it be less expensive to have the labor done for the final gear, and the diff at the same time??
Thanks
Chris
Edit: PS- I will be boosting in the future, but right now I dont have any engine mods worth mentioning...
Old Aug 30, 2001 | 07:01 AM
4373's Avatar
A Kaaz differential or a Kaaz 1.5 or 2 way Limited Slip Differential?
Old Aug 30, 2001 | 07:04 AM
cjb80's Avatar
I think it's a 1.5 way LSD
Old Aug 30, 2001 | 07:07 AM
4373's Avatar
See this; https://www.s2ki.com/forums/showthread.php?...hlight=kaaz+lsd
and a search on Kaaz LSD will render you an additional 19 threads.
Old Aug 30, 2001 | 07:32 AM
cjb80's Avatar
What about the final gear??? Is that part of the LSD??
I want to get a 4.44 final, I guess I should wait until I can afford that before I go installing a new LSD??
Old Aug 30, 2001 | 07:43 AM
4373's Avatar
It would make better sense and save labor dollars to install both the final gear and LSD at the same time.
Old Aug 30, 2001 | 07:49 AM
cjb80's Avatar
OK I ordered it.. damn it!!!
When I read that several people said it was the best mod for the s2000 I picked up the phone.. I am such a weakling!!
Old Aug 30, 2001 | 07:50 AM
4373's Avatar
[QUOTE]Originally posted by cjb80
[/QUOTE You have PM
Old Aug 30, 2001 | 07:52 AM
cjb80's Avatar
Whats the part number for the Kaaz 2 way LSD??
Old Aug 30, 2001 | 06:20 PM
rocketman's Avatar
I am pretty sure the Reverend put a kaaz diff in his s2000. He even had a web site where he described the install. Try a search on his posts or on differential threads.
