differential oil
I just bought the le 607 and called the dealer to ask if one quart was enough because i bought it from go fast labs and on the the website its says one quart is enough. Anyways the dealer said it is not enougt.......grhhhhh so does anyone or can anyone comfirm this??? How much do I need please let me know as I need to change it soon and need to order more if i need more.
One quart is enough for the diff.... The transmission needs more than one bottle..
https://www.s2ki.com/forums/index.php?showtopic=99995
The diff takes 0.78 qt. on fluid change, but this depends on how well it was drained. You simply fill it till it overflows from the fill hole when the car in level. Do you really want a dealer who thinks they need 2 qts to fill your diff to actually touch your car?
Originally Posted by s2kv,Dec 15 2005, 03:18 PM
Yeah figured if someone knew I wouldnt takeit to them, anyone know a good tech in around los angeles or close to la in california??
