diffrent tires on rear
okay well i one of my rear tires took a crap.. long story short i have a potenza re750 245/40/17 as one rear.. and a toyo t1r 245/40/17 as another..
is this going to hurt my differential?? if i floor it doing like 60mph is 6th gear (bogging) the car pulls HARD to one side.. i know i need to get the same tire brand etc back there, but its going to be 2 more days before i can get 2 more toyo's for the rear.. so again.. am i going to see some problems? i have to drive 20 miles to work mon and tues and i can only get the tires on wed.... will i be okay?
thanks
thanks
First make sure that the tires pressures are correct on all tires.
Both these tires have the same static overall diameter, however, one may not be as firm as the other at the same pressure. That is, one may sit more squat, have more contact patch than the other. This will play havoc the actual diameter. One may actually be "flatter" than the other and this will produce the effect you've felt. Whether or not it will have an adverse affect on the diff will depend on just how different the dynamic overall diameters are.
thanks for the info guys... ill try to measure them.. its only temp. until i can get 2 new toyo's in (prob by wed).. thanks!
btw ive always kinda been scared of our diff's (heard how weak they are) how much would a new diff + install run? i figure new diff = 1k and install would be like 200$?
yes you'll tear up the diff using odd sized tires. its in the owners manual that you can't use the spare on the rear because of this.
if I were you, i'd put both fronts on the rear, put the odd sized tires on the front, and drive carefully since your handling will be out of whack.
Originally Posted by mic_crispy,Jan 30 2006, 10:16 AM
no no no i have a potenza 245/40/17 on one rear, and a toyo 245/40/17 on the other side... so its not odd sized tires.. just diffrent brands.. im just wondering if this will be okay until i can get 2 new toyo's in.
what will tear up the diff is if the tires were of different circumference. like if one of the tires was a 225/50/r16, that would be a big no no.
