Disable ignition
Old Jan 25, 2009 | 05:33 AM
Elroy's Avatar
Default Disable ignition
Is there a QUICK and EASY way to disable the ignition and engage the starter so that the S does not start but rotates the engine?
J
Old Jan 25, 2009 | 06:17 AM
negcamber's Avatar
Might do some research in the Helms to see if there is a fuse for the coils if you don't want spark.
Otherwise, you can pull the fuse for the fuel pump...the car will turn over (it will get spark), but without fuel...no bang. Look in the FAQ to see if there are compression test instructions...part of those instructions should have you pull the fuel pump fuse...that way you can identify which fuse it is.
Old Jan 25, 2009 | 10:40 AM
jeggy's Avatar
how about just unplugging each coils?
Old Jan 25, 2009 | 02:20 PM
jezzder's Avatar
or take the leads of the spark plugs... just make sure to number them so you dont forget which is which when you plug them back together
Old Jan 25, 2009 | 04:24 PM
RedY2KS2k's Avatar
Ever looked at an S2000 engine?
Old Jan 26, 2009 | 09:17 PM
Artisan7471's Avatar
Yes you need to take out the ignition fuses under the dash.
MarcS2000
Feb 10, 2017 01:24 AM
Lookatmy240
Dec 25, 2009 09:09 PM
JToolz
Aug 18, 2006 08:04 PM
05S22
Aug 22, 2005 05:21 PM
Killashahmafia
Feb 28, 2005 09:08 AM
