distance from rear subframe to the ground
Hi, I'm working on a locost project and I will be using the entire rear subframe from my old s2000. I would like to mount it at the same height so I don't dork with the suspension geometry. My problem is that my subframe is sitting on my workbench instead of on the back of my car. Could someone tell me how far above the ground the large round tubes on the bottom of the rear subframe are. Also is this the same distance in the front as the back (ie. does it sit parallel to the ground)
Thanks for your help,
Sam
Sam
Hopefully someone can take a tape measure and check under their car to see how high the bottom of the rear subframe is off the ground. It should only take a couple of seconds, and I'd really appreciate it!
Thanks,
Sam
Thanks,
Sam
