DIY abs sensor
Old Apr 8, 2009 | 10:23 PM
s2kbtos's Avatar
Default DIY abs sensor
is there DIY abs sensor, i've been searching, but not cigar. i'm trying to replace the rear ones.
Old Apr 8, 2009 | 10:32 PM
SgtB's Avatar
Do you mean an actual sensor build or just swapping them for new oem ones? Swapping them is easy. I can't give you specifics, but they are held on the hub with one bolt, and then various other bolts secure the wire up to the connector. Just remove all the bolts, unclip the connector, and reverse to assemble.
EDIT: Just checked the HELM manual. It's like I said. 4 bolts secure the sensor and the cable. The cable goes through a grommet under the fender which I'm pretty sure goes into the trunk. You should be able to access the connectors by pulling back either side of the trunk trim. I may have the manual upside down though, so eyeball the grommet to see where the connector goes.
Old Apr 9, 2009 | 02:51 AM
Olegator's Avatar
easy to do. I take it you streched the cables too much?
jezer101
Feb 15, 2014 01:01 AM
AP1Driver
Oct 3, 2013 05:05 PM
gerk
Mar 6, 2010 12:09 PM
chorne1787
Jun 25, 2009 06:58 PM
