DIY Diff Replacement
Old Oct 21, 2010 | 01:27 PM
  #31
dammitjim's Avatar
+1 Chock the front wheels really well or use 4 stands.
Old Oct 21, 2010 | 03:23 PM
  #32
modMonkey's Avatar
Originally Posted by s2klariat,Oct 21 2010, 01:16 PM
One thing I would like to add to this is you should NEVER crawl under a car where the rear end is lifted and the front isn't unless the front is secured with some sort of roll stop. If the weight shifts the car could slip and fall even if it is on jackstands. If I need to work under the rear I lift the whole car onto 4 jackstands just incase. I'm sure plenty of others would agree. Other than that nice write up
Yup. A So-Cal member passed way during a diff swap when the car rolled and fell on him.
Old Oct 21, 2010 | 06:27 PM
  #33
AusS2000's Avatar
The trick with the bolts is to get good access, a good hex socket, and a good hard wrench on a breaker bar.
The car will need to be high off the ground and you may need to turn the driveshaft and reapply the handbrake a few times.
Old Oct 25, 2010 | 02:40 AM
  #34
starchland's Avatar
Don't forget to mark all your joints before disassembly if not already done
Old Oct 27, 2010 | 07:00 PM
  #35
billiardboy904's Avatar
a year and a half later, the car is still running great.
Old Mar 14, 2011 | 08:16 AM
  #36
AshtonWMS's Avatar
is there any chance of seeing the photos for this again?
Excellent write up
Old Mar 15, 2011 | 11:22 AM
  #37
Olegator's Avatar
pics dont work : /
Old Jul 26, 2011 | 10:42 AM
  #38
scotty68's Avatar
nice write up. thank you
Old Aug 3, 2011 | 03:15 PM
  #39
robrob's Avatar
Here's another diff swap how-to: http://robrobinette....ifferential.htm
The propeller and drive shaft bolts are supposed to be replaced after they're removed. For removing the propeller shaft bolts I recommend a hex socket, extension and impact wrench. Make damn sure they hex key is fully seated into the bolt (hit it lightly with a hammer) before hitting it with the impact wrench.
Old Aug 4, 2011 | 04:43 AM
  #40
dedonderosa's Avatar
GOOD INFO
