DIY front lip install
Old Oct 23, 2007 | 10:29 PM
raisantos's Avatar
Default DIY front lip install
i tried searching for this? didn't find it on the DIY list. i want to buy one but i'm trying to see if i can install it myself on my MY07, you know, to save some cash
also i found a place that sells it for $358.00
H and A
are they reputable? and is it a good price?
rai
Old Oct 24, 2007 | 03:42 AM
daktruckie99's Avatar
H and A is very reputable. Install takes all of 5 minutes and anyone can do it.
Go for it
Old Oct 24, 2007 | 05:35 AM
animeS2K's Avatar
Yeah, it's definitely easy. I've taken mine on and off a few times and it's just a bunch of (12mm?) bolts.
Old Oct 24, 2007 | 06:47 AM
S2kracka's Avatar
H&A is a good place and its a fairly easy install.
Check on eBay though, there was a dealership selling actual Honda OEM lips for really good prices. I think I paid under $300 shipped.
Old Oct 24, 2007 | 07:28 AM
SIIK2NR's Avatar
On a Mechanics scale of difficulty from 1-10, the DIY install of the front lip is less than 1.
Yoooo can Dooooo it!!
Old Oct 24, 2007 | 08:05 AM
8_ball's Avatar
Job is much easier if you can jack up the car, not a lot of room to get the bolts in underneath if the car is not jacked up. Also, a second set of hands is helpful in getting the lip positioned and held in place while bolting it on. Lastly, seems like I'm in the minority but I had a heck of a time getting the self-tapping screws lined up and seated properly on the inside of the front wheel well. Driver side was OK but I really had to wrestle with the passenger side to get everything lined up. There is a fairly detailed installation page somewhere on this site, which is also helpful. I'll see if I can find it and post the link.
Old Oct 24, 2007 | 09:22 AM
jdmgpw04's Avatar
really easy ...
if your really slow maybe 10 minutes tops..
good luck ...
and yes regular joe's can do it.......
Old Oct 24, 2007 | 09:46 AM
8_ball's Avatar
Here is the link to the instruction sheet
http://www.handa-accessories.com/S2000/s2kfus04.pdf
Old Oct 24, 2007 | 10:26 AM
hondaf1's Avatar
if you can change the oil, you should have no problem.
Old Oct 24, 2007 | 12:03 PM
animeS2K's Avatar
If you know which end of a socket wrench is the right end to hold, you shouldn't have a problem
