DIY: Rebuilding your transmission
Old 11-26-2010, 09:42 AM
  #21
chef-j's Avatar
Old 11-26-2010, 11:55 PM
  #22
ronnuke's Avatar
Originally Posted by flyingtoaster,Nov 26 2010, 01:16 PM
Did you replace the synchro sleeves? Which oil are you going to use now?
Yes I replaced the synchro sleeves (they came with the sets)
I am using the new Honda MTF for now but will probably change to either the GM friction modified or the Amsoil offering at the next change. I wanted to see if the "new" transmission would benefit from the spec'd fluid or not....so far so good but it is not as smooth as either of the other 2 mentioned.
Old 11-27-2010, 10:57 AM
  #23
flyingtoaster's Avatar
My transmission is feeling a little notchy. Honda MTF was changed 10k miles ago, but I will probably switch too. 99% of the cars that use Honda MTF have a transaxle with an integrated differential. I believe the S2000 trans is the only manual trans made by Aisin and I don't know if Honda had us in mind when they had it formulated. Have you tried Redline?
Old 11-27-2010, 12:08 PM
  #24
ronnuke's Avatar
No, never tried the Redline. Maybe I will consider it.
Old 11-27-2010, 01:00 PM
  #25
wrecked's Avatar
redline is good stuff!!
Old 11-27-2010, 01:14 PM
  #26
AusS2000's Avatar
This is going straight to the pool room!
Old 11-27-2010, 01:30 PM
  #27
AusS2000's Avatar
And by that, I mean straight to the FAQ.
Old 11-27-2010, 04:44 PM
  #28
ronnuke's Avatar
Old 11-27-2010, 09:03 PM
  #29
madcowdk's Avatar
*subscribed
Thanks!!
Old 11-29-2010, 05:21 PM
  #30
phaphapho's Avatar
you are the man
Quick Reply: DIY: Rebuilding your transmission
