Soft top Hook Catch come loose
I think its called the catch,,,
its this bit..
by https://www.flickr.com/photos/switchmorgan/, on Flickr
Its not secure it is all over the place.
Is this an easy fix?
Thanks in advance
its this bit..
Thanks in advance
Based on the angle, one of the #3 phillips screws fell out.
Remove the sill plastic (the one that typically gets replaced with a gauge pod) and drivers side sun visor. You will then be able to partially pull back the long trim piece and access the screws.
You can remove the center light cover, interior light assy, and both sun visors and completely remove the long trim piece.
Take a screw from your other catch measure it.
You might find this DIY helpful. If you are pulling everything apart anyway, maybe consider replacing with hardtop catches?
https://www.s2ki.com/forums/s2000-un...rikers-517300/
