DIY: Trunk Swap
Old Dec 10, 2009 | 08:42 PM
Matts_04_s2k's Avatar
Yea I have tried pushing and pulling on it, also after we moded the mechanism we tested it before installing it, and it was all good. I just dread pulling all those panels off.
Thanks for the input though, much appreciated
Old Jan 30, 2010 | 05:51 AM
phonedrn8's Avatar
ah dang that was a bummer , any updates on it ?
Old May 11, 2010 | 09:01 AM
ertbll's Avatar
hey is there a bulletin onn how to align a vis carbon fiber trunk just got one it doesnt completly aling on the right side
Old May 22, 2012 | 07:32 AM
epan319's Avatar
nice
its easy
Old Feb 13, 2019 | 10:23 AM
AlexS2kBerlina's Avatar
Images not founds
Old Feb 13, 2019 | 12:27 PM
Car Analogy's Avatar
Not surprising since the original posts are from well over a decade ago...
Old Aug 23, 2022 | 08:26 PM
jaykobean's Avatar
Anyone know how to install a carbon fiber trunk with no keyhole?
Does the trunk latch bar that attaches to the keyhole need to be there for the trunk to open?
Old Aug 24, 2022 | 09:10 PM
spider2k's Avatar
Active Streak: 30 Days
the bar that runs to the key cylinder is just for opening with the key. you can leave it out but if the actuator doesnt work for whatever reason its gonna be bad.
Old Aug 25, 2022 | 06:13 AM
engifineer's Avatar
As I mentioned in the other thread, you could rig a pull cable that came out behind the bumper for an emergency latch. Just need to make it so it pulls the correct direction but I figure it is doable.
My trunk lid is "hot swappable" lol I put a Deutsch style connector right where the factory wiring sits near the hinge arm so I can swap between my nice OEM trunk lid and the slightly less nice trunk lid with the wing. I generally leave the wing lid on now since I just run XSA for autocross (aka do not need to swap it between track and autox) but it is a nice feature. Something to think about if people are using a different trunk lid to drill and mount a wing for the track. Mark all the alignment on both lids and with the easy to get to connector, it takes less than 10 min to swap. Probably closer to 5 min
Old Aug 25, 2022 | 07:12 AM
spider2k's Avatar
I saw the post after this one. A bicycle brake cable would work well if you wanted it run into the cabin. You could even mount a release handle somewhere under the dash or the console.
Triple-H
28
Jul 9, 2011 05:02 PM
ericshun
Oct 25, 2007 11:21 AM
Ro_Ja Boy
Nov 11, 2003 10:41 AM
