DIY valve cover question
Old Aug 8, 2008 | 08:13 AM
spa01s2k's Avatar
Default DIY valve cover question
I got another valve cover that I would like to do a different color. Is there a DIY on what to use to strip it and how to repaint it?
Old Aug 8, 2008 | 08:31 AM
daktruckie99's Avatar
TBH I just had mine sandblasted and powder coated for $60 so it might not be worth your trouble. That is up to you.
Old Aug 8, 2008 | 11:49 AM
spectacle's Avatar
There are a few DIY's on this in the DIY forum of clubrsx.com.
Go to their DIY subforum and do a quick search
Old Aug 8, 2008 | 09:35 PM
spa01s2k's Avatar
^^ Thanks for the info.
Old Aug 8, 2008 | 09:42 PM
craig2teg's Avatar
When I did the valver cover on my Integra I usedAircraft Paint Remover to remove the O.E. finish. This product can be found at any local automotive/hardware store. IMO I would recommend using the aerosol version, just for the ease of application. For the finish I you're going to need to use a high temp primer and paint or get it pc'd.
Old Aug 8, 2008 | 09:54 PM
frofro24's Avatar
I use aerosol gasket remover, it seems to be a bit more powerful than the areosol paint removers I have used in the past. To finish it I would use a high temp paint like craig2teg suggested...
hvAlfaWant_S2000
Sep 10, 2015 12:30 PM
kwakhead
Apr 2, 2014 07:31 PM
InVTEC
Sep 6, 2011 04:29 AM
superman6074
Jan 26, 2008 07:06 AM
rikhemi
May 20, 2005 03:32 PM
