Do all test pipes sound the same?
Old Apr 18, 2004 | 07:36 AM
all-trick'd-out's Avatar
Default Do all test pipes sound the same?
I am probably going to get a test pipe as I am looking for a louder exaust note and don't want to change out the exaust. I researched a bunch of threads and found everyones opinions clashed. I just want to put on the test pipe and an intake in.
Old Apr 18, 2004 | 08:05 AM
xviper's Avatar
A test pipe is just a hollow tube that replaces the catalytic converter. You may get very slight variations from the material used to construct this pipe, but a hollow tube is a hollow tube unless you start adding lumps and bumps to it. Not much science involved here. You're trying to read far too much into things.
Oh, did you know that you'll need to find some way of fooling the ECU once the O2 sensor is gone or changed position?
Old Apr 18, 2004 | 11:22 AM
swtazn97's Avatar
a better question would be....
Q: Do all Test Pipes smell the same?
A: Yes, it's going to make the air you breath around you more STINKY!
Keith
Oct 24, 2008 12:27 PM
SpaZilla
Oct 26, 2005 11:17 AM
Tony Yeung
Sep 8, 2005 12:36 PM
