Do I have a fake oil cap?
Old Sep 12, 2023 | 08:14 AM
newS2000's Avatar
Default Do I have a fake oil cap?
I have 3 oil caps now. The new one I purchased on amazon looks slightly different. It has a bevel to underside edge (when you look at it upside down)
Here's the packaging it came in
Spoiler
Here is a photo of the one that came on my engine and one I found behind my engine when I did my s2000's first oil change (I'm the 5th or 6th owner). The newest one also has a 2 printed inside it.
Spoiler
The first two have damaged threads
Spoiler
I was thinking at first the rubber seal was different too... but after thinking about it a tiny bit more I realized the new one just has a fresh seal and the first two's seal has just been pressed flat.
Any experts or oil cap OCD experts out there know if this new one I have is genuine?
Old Sep 12, 2023 | 08:17 AM
newS2000's Avatar
I just noticed the one I found behind my engine that says A13 inside instead of 2 also has AP1 SJ (or API) on the cap that the others don't have.
Old Sep 12, 2023 | 08:28 AM
engifineer's Avatar
I have no expertise in recognizing a fake oil cap, but I would say if it works it works. Put it on, drive around, make sure it does not loosen. If not, it likely is ok Generally the oil cap on this car will tighten quite a bit after you put it on, not loosen. I tighten mine with two fingers, have to use my hand to take it back off.
I would upgrade to a 710 cap though. I hear those are the bomb ....
Old Sep 12, 2023 | 08:40 AM
newS2000's Avatar
@engifineer I'll try the 710 cap when I refill my blinker fluid & change the summer air in my tires for winter air.
Old Sep 12, 2023 | 06:03 PM
noodels's Avatar
Just ordered a new one, its been on the list
Old Sep 19, 2023 | 06:23 AM
Chuck S's Avatar
Looks genuine to me.
Yep the flat seals are because they're old and probably fossilized. Replacing the seal (15610-pcx-a01) is simple and inexpensive ($6) but the complete cap isn't much more ($12). I replaced my oil cap a couple years ago as it took giant pliers to get the original off. Was the rubber seal I suspect.
The part number is indeed 15610-pcx-a01 for all model years and the marking inside is probably a die number from the machine is was produced on.
-- Chuck
Old Sep 19, 2023 | 07:51 AM
thoiboi's Avatar
I heard someone mention this before when talking about counterfeit items: "where's the value in counterfeiting something like this". It's not like it's a high value item that can net some amazing returns.
Old Sep 19, 2023 | 02:29 PM
noodels's Avatar
My new one has the bevel as above,looks like its de-shamferd from manufacture process to remove sharp edge.
dibi
Jul 3, 2009 11:49 PM
