Do I need to cut the bumpstops?
Old Jul 28, 2004 | 01:48 PM
What The's Avatar
Default Do I need to cut the bumpstops?
I've installed the Koni yellows along with the KG/MM race springs. I have them set on the lower perches. Do I need to cut the bumpstops to give the shock more travel? Current drop is about 1.75"
Thanks!
Old Aug 2, 2004 | 09:35 AM
What The's Avatar
bump. Anyone? Did you leave your bumpstops intact when you installed your springs or springs/shocks?
Old Aug 2, 2004 | 09:49 AM
speed4tu's Avatar
I didn't cut mine when I had my koni's on the lower perch with KG/MM Race springs.
Old Aug 2, 2004 | 10:22 AM
TubeDriver's Avatar
Not sure this helps but my GC coilovers instructions said to trim the bumpstops (there are 3 sections an I trimmed off 1 or 2 (can't remember off hand). Bumpstop can prevent your suspension from bottoming out and possibly damaging the shock. If you can't get a clear answer from KG/MM or a dealer, I would consider trimming the bumpstop but leaving part of it installed.
Old Aug 2, 2004 | 10:43 AM
dut's Avatar
dut
- I would cut them...
IwantaS2000
Jul 18, 2005 03:08 AM
RazorV3
Aug 18, 2004 09:59 AM
leatherface_ca
May 19, 2004 07:59 PM
kush only
Jan 2, 2004 07:34 AM
monster57
Aug 21, 2003 08:24 PM
