Do timing chains need to be replaced?
Old Jun 16, 2004 | 08:46 AM
gdonahue's Avatar
Default Do timing chains need to be replaced?
It's a general question. I've heard over time they "stretch" and need to be replaced and I've also heard that they never need to be replaced. Any clarification would be greatly appreciated.
Old Jun 16, 2004 | 08:59 AM
cornercompacts's Avatar
my mercedes had a timing chain and it had to be replaced
Old Jun 16, 2004 | 09:09 AM
gdonahue's Avatar
At what mileage?
ELAhrens's Avatar
My daughter's POS Saturn did and it should have been done before it self-destructed. Valves stayed open pistons went up & down about twice Result was there was more metal in the pan than oil - Newer Saturns don't have that problem - so I've been told.
Had it replaced on our 93 Tracer at 90k miles - just to be safe.
Old Jun 16, 2004 | 09:17 AM
gdonahue's Avatar
It's because they have Honda motors in them now.
Old Jun 16, 2004 | 10:50 AM
vvtli78k's Avatar
they say not to do it, i would say at about 150k- 180k.
Old Jun 16, 2004 | 12:20 PM
mxt_77's Avatar
Oddly enough, I don't see it on the maintenance schedule. However, I would definitely do it by 90K miles... sooner if you track/race the car.
When I was in high school, I had a Nissan Sentra (with a deisel engine) and the timing chain broke at about 110K miles. Not a cheap fix.
Old Jun 16, 2004 | 12:41 PM
Ludedude's Avatar
Administrator
A good rule of thumb is about 100,000 miles to replace a metal timing chain in a normal street driven engine. Obviously cars with a lot of track miles should do this sooner. Being that this is an "interference" motor, if the chain breaks the valves will come into contact with the pistons and lead to a much more expensive repair.
Old Jun 16, 2004 | 01:16 PM
cdelena's Avatar
A high quality chain with a good tension system should go the life of the engine without a problem. Even the timing chains on old V8's went for the life of the engine, usually over 100K miles.
Old Jun 16, 2004 | 01:44 PM
Ludedude's Avatar
Administrator
I busted a chain on an old V8. 1970 Olds 442 motor to be exact. Just over 100,000 miles Bent a few valves. Ugly,
