I'm trying to replace the center fender bolt that is the "non-painted" bolt in the center. I've done a bunch of research and have bought several bolts I thought were the right one but each one does not quite match. This bolt has no paint and has a dull/flat finish to it with no markings on the top.
Here is what I have bought so far with no luck on a perfect match: Either the center of the top of the bolt has markings (the original one does not) or it is too glossy and does not match (the original one has a flat finish). Am I missing something, or do they not make this bolt anymore exactly as it came from the factory? I'm trying to match for a year 2000 AP1.
90108-S0A-003
90108-SF1-000
95701-0801608
90105-SV1-000
Damn there was another thread about this late last year and I found the right part number for the guy. But do not have time right now to go searching for it. Just holds the fender I believe.
Guy on the other thread seemed to indicate it was correct. But never came back and confirmed for sure.
But that bolt I am pretty sure is always that color (has a different coating) for some reason. Not sure why. But even when you look at the part description that one has a different coating on it.
The -003 suffix in the part number indicates a variation or revision including different colors. As a common Honda bolt I can see it being made more corrosion proof. 90108-S0A-000 (the "base" part number) doesn't turn up anything and may no longer exist after being superseded by .003.
