does anyone know where to buy clutch alignment tool??
Old Jun 7, 2004 | 11:44 PM
alexchou's Avatar
Default does anyone know where to buy clutch alignment tool??
i've just bought ACT's PP, OEM disk, throwout bearing and comptech's flywheel and my mechanic needs the alignment tool to do the job. i've been calling dealers but they don't sell the alignment tool?!?... ACT don't have it either... so where can i buy this tool?
thanks
Old Jun 8, 2004 | 02:19 AM
jguerdat's Avatar
You should be able to get one at any decent parts store. It prolly won't be specific to the S but a universal tool should work just fine. I'm surprised that a mechanic doesn't have one in his tool box - if you replace clutches, it's needed.
I had one that I bought back in the early '70s but gave it away recently because I'm old enough that I don't want to be doing these things myself. The DSM guy I gave it to said it worked fine so sizes shouldn't be a problem...
Old Jun 8, 2004 | 03:31 AM
fperra's Avatar
A wood dowl or broonstick handle works fine.
Old Jun 8, 2004 | 05:36 AM
Squeezer's Avatar
any honda parts department will sell it to you. 07PAF-0020000 is the part number. but yeah you could go to autozone and get one for a civic or prelude, it should be the same.
Old Jun 8, 2004 | 06:53 AM
cdelena's Avatar
Exactly right.. the only purpose is to insure you tighten down the assembly with the hole in the middle in a straight line so you can stick the transmission. There is nothing special about the tool.
Old Jun 8, 2004 | 07:00 AM
kane.s2k's Avatar
Or two screw drivers
Old Jun 8, 2004 | 07:16 AM
davepk's Avatar
Get a new mechanic.
Old Jun 8, 2004 | 07:50 AM
Partshelper's Avatar
if you want the real deal the only place to get it is direct from honda, and they have to order it. other methods do work as well, but you will only know if they worked once you have assembled the car all back together
Old Jun 8, 2004 | 08:37 AM
jguerdat's Avatar
You'll know it before the car is back together since you won't be able to get the transmission in...
Old Jun 8, 2004 | 10:58 AM
Asura's Avatar
'94 Accord alignment tool will work. Pep boys or Autzone should carry it. You should be able to eyeball it. Either way your mechanic is
