View Poll Results: Does Synthetic oil reduce oil consumption?
Voters: 18. You may not vote on this poll
Some data to be wary of: Most people switch to synthetic after or during the break-in period, where you will naturally consume more oil. As the break-in period goes away, so does most oil consumption (usually).
Most synthetic oils have a higher flashpoint and will naturally burn less in the engine. How much so can only be accurately determined on a broken-in motor and prefereably the same motor (though across different motors/samples).
Just a thought, anyone who votes should keep that in mind. I'll refrain from voting since I went to synthetic at 3k (before the motor was fully broken in).
I have very little oil consumption now (6500 miles), though I have nothing to compare it to.
Banned
Originally posted by sfphinkterMC
which synthetic oil do u use.
i'm gonna go to the expensive REDLINE stuff, whadda u think?
Hope this helps
i switched to syn oil at 6k, im now at 9.5k and it has already managed to burn up a full quart! is my car busted up or does oil consumption last a really long time? how many more miles should my car burn oil till i should get worried?
Mike
Mike
mikerino
05-12-2003 08:14 PM
