this doesn't seem right. an oil question
Old Jul 27, 2005 | 02:17 PM
Wisconsin S2k's Avatar
Default this doesn't seem right. an oil question
Ok, it seems like we have a LOT of different views about oils and their functions.
My name is Ray and I am a senior mechanical engineering student.
I've had my fair share of chemistry classes, but I will be focusing on the mechanical aspects of oil and of course the mechanical properties of your engine since that is my major.
The heat transfer basics:
Oil is not just for lubrication. Oil is the most important thermo transfer substance that your car has. The antifreeze/water mixture you have only gets secondary heat that has to move through the metal engine walls before reaching the liquid. Your oil on the other hand is right there where the heat is being created and therefore has the opportunity to move more heat away at a faster rate. Your oil can get a lot hotter than your coolant does.
Thinner oils will heat up and cool down quicker than thicker oils. However; thinner oils are not able to hold as much energy (heat) as thicker (denser) oils. Also, oils that are to thick or dense will not heat up fast enough (taking heat away from the engine) or cool down fast enough. Thicker oils can also create heat do to friction. You need to have a balanced viscosity.
For our cars anything with a viscosity below 5w may not be holding enough energy for a good heat transfer and anything above 40w may not be soaking up enough heat and anything above 30w may even generate heat.
I saw this posted somewhere. The last part doesn't sound right. This is in regards to a civic that honda recommends to use 5w20. The guy makes it sound like using 5w30 or 5w40 would CREATE heat from friction....
Old Jul 27, 2005 | 02:36 PM
jasonw's Avatar
I wood espect better spelling from a senior mechanical engineering student...
Old Jul 27, 2005 | 03:21 PM
xviper's Avatar
Students can tend to be a bit "gung ho". He may be right or he may be wrong. Give him a few more years till he graduates and works in the real world before taking him with full validity. In the meantime, we've got Road Rage (that is, when he signs on).
Old Jul 27, 2005 | 03:25 PM
AusS2000's Avatar
Is that a joke? If so, pretty funny. If not, pretty sad.
Old Jul 27, 2005 | 03:26 PM
mwy23's Avatar
engineering != spelling bee champ... in most cases
Old Jul 27, 2005 | 03:35 PM
mikegarrison's Avatar
Sad but true. I no beecus I are an enjineer.
Old Jul 27, 2005 | 03:39 PM
Ludedude's Avatar
Administrator
Lust wiek i cudnt even speel enginaear
Old Jul 27, 2005 | 04:13 PM
jasonw's Avatar
Us pun-loving software engineers know our homofones!
Old Jul 27, 2005 | 04:26 PM
AusS2000's Avatar
Homofone???
Is that for calling your same sex significant other?
Old Jul 27, 2005 | 05:11 PM
CaptainMike's Avatar
And dis week I IS one!!!
It just seemed incomplete...
