Down shifting into 2nd
I've jus taken it for a test drive but I still grinded 2nd once when cold. This could be due to me getung used to the clutch point changing? I'll try it for a week and then report back.
One thing i did notice which has been happening the whole time is that when i am at a standstill, push the clutch in the is a little clunk when i try and select any gear. Could this be that that the slave cylinder is not pushing the selector fork quick enough?
Just so everybody knows i have replaced the clutch kit, flywheel, CMC, fluid so far. The only things that haven't been replaced are trans oil (due for replacement in Nov) and the slave cylinder.
If it's a downshift you probablly have a bad synchronizer from a misshift. Nothing you can do about it. One gear grinding is a giveaway. If they all where notchy, I would say the clutch.
DO NOT skip gears. The synchros on this car are fragile.
Originally Posted by paul2011s2000' timestamp='1335010710' post='21629542
Great drawing SpitfireS.
So your saying you have trouble getting into second and sometimes sixth? You sure you haven't been skipping gears on the way up the box?
Ok thanks for the advise. Thinking about it I dont usually skip going up the box, mostly on the way down.
I've been for a few more test drives with the CMC rod adjustment and it feels better so far, could be placebo at the moment though so i will keep an eye out during the week
lunardeathgod
Jun 19, 2012 03:47 AM
mannys2k909
Aug 6, 2010 06:37 PM
