Driver Side Camber Wear - Any Ideas?
Old Jan 23, 2009 | 06:09 AM
aeonracer's Avatar
Default Driver Side Camber Wear - Any Ideas?
So I recently put some new shoes on the S, and noticed I had fairly significant camber wear, but oddly enough ONLY on the drivers side (front and rear). On the front, the outside of the tire still has 1/4" of tread left, but the inside has maybe 1/16th. The rear driver side outside had ~ 1/8" left but the inside was showing belt. Both passenger side tires (front and rear) are wearing perfectly even.
I figured my alignment was out of whack, so I got it aligned yesterday. It should be noted that my car is lowered ~1", so I was limited in my adjustments.
Old Setup:
Front toe - 0.25 deg in
Front camber - -0.6 deg
Front caster - 6.2 deg
Rear toe - 0.50 deg in
Rear Camber - -2.1 deg
New Setup
Front toe - 0.0 deg
Front camber - -0.5 deg
Front caster - 6.4 deg
Rear toe - 0.25 deg in
Rear camber - -2.0deg (couldn't get it any further, wanted -1.5 deg)
The new setup is with me sitting in the car.
I'm completely stumped as to why there was such a significant camber wear effect on the driver side. Nothing in my before or after alignment clearly supports this kind of tire wear. I'm hoping the toe adjustments even it out a bit (especially in the rear).
Has anyone every heard of anything like this? Any suggestions?
Old Jan 23, 2009 | 07:38 AM
R1_Pilot's Avatar
so your total toe in is .25?
Usually when you get camber wear is mostly a toe problem. I ran -3.2 in the rear and dont have a problem. Do a search on my screen name and you will find somewhere my alignment settings, I just cant remember what toe I am running but I want to say 1/4 total in ..
Joaquin
Old Jan 23, 2009 | 08:09 AM
aeonracer's Avatar
Yes, 0.25 deg total of toe in. It was 0.50 deg before the alignment.
I'm stumped... I wouldn't think 0.50 deg would have such a dramatic effect, especially on only one side of the car... I guess unless anyone else has any other suggestions I'll just have to see how this next set of tires wear.
Old Jan 23, 2009 | 11:32 AM
R1_Pilot's Avatar
Try posting in the racing forum. You might get more responses there.
Joaquin
Apex1.0
Aug 23, 2014 08:57 AM
SXYS2k
Dec 6, 2011 09:51 AM
JVS2
May 26, 2009 10:02 PM
gerryk
Oct 19, 2003 09:46 PM
