Driver's rear wheel bearing....
Old Sep 11, 2009 | 08:10 AM
my2ks2k's Avatar
Default Driver's rear wheel bearing....
so i replaced my driver's rear wheel bearing in Feb 08; it is now Sept 09, and i've got bearing noise again. Has anyone else experienced this? what are the odds of getting a bad bearing? or maybe i somehow managed to mangle the install? i don't really see how, it's pretty straightforward...
anybody have any thoughts?
Old Sep 11, 2009 | 09:31 AM
mLeach's Avatar
did you also replace the hub?
Old Sep 11, 2009 | 03:03 PM
jyeung528's Avatar
good questions
Old Sep 11, 2009 | 03:09 PM
Fast Jack's Avatar
^^ yep, dats that da big ? If the hub shaft is scored putting another new bearing on there,not a good idea.
Old Sep 11, 2009 | 07:20 PM
my2ks2k's Avatar
I did in fact replace the hub. One more reason why I'm stumped! Uggg
Old Sep 12, 2009 | 02:21 AM
JasonSBAP1's Avatar
dont worry bro cause i also replaced the hub and its only been 6 months and i am getting the beginnings of the problem once again as well !! clicking... but heres my stumper i went to go and have them retorqued before the moise got any worse and they arent loose in the hub... i am afraid its just going to happen again !!
fyi... if one side went bad its only a matter of time before the other side does as well !!
i feel like this will be a continious problem for the life of my S... i have heard its a service bulliten but honda will not recall it !! the reason this happens if because for some reason the axle bolt either stretches or backsoff the axle and the bearing creates a groove in the hub !!
the last time mine went out it sheared the bolt and half the splines off of my drivers side axle... i almost lost my precious wheel (staggered cp-r spinthart) and took out my abs since the caliper came out of standard position !
maybe driveshaft spacers create less of a strain on the axle length changing from being dropped ???? I dunno !
Old Sep 13, 2009 | 07:40 PM
my2ks2k's Avatar
interesting...i am lowered...wonder if that has any...bearing...on the situation
Old Sep 13, 2009 | 08:17 PM
dimi's Avatar
Don't even ask me how much bullshit I've had to deal with when changing a bearing. Make sure you torque to 220-230 not 180.
Old Sep 13, 2009 | 08:32 PM
toniotran's Avatar
replace both hub and bearing, but before you do make sure to inspect the knuckle for damage/warped. After re-torque, make sure to stake the axle nut.
Old Sep 14, 2009 | 05:23 AM
my2ks2k's Avatar
yeah i did all that back in Feb 08. what else ya got
AZ-S2000
Jun 13, 2014 02:57 AM
dagle
Oct 17, 2012 09:27 PM
gbaker
Jun 27, 2012 04:07 PM
vufgew
Feb 4, 2012 08:20 PM
JakeAP1
May 26, 2010 01:42 PM
