Driving with an open hood!?
Old Mar 11, 2003 | 03:45 PM
JL9000's Avatar
Default Driving with an open hood!?
Hey guys, recently I was driving my mother's TL, and after a while I noticed the hood seems a bit high, so I pulled over the road to check it out and to my surprise, the hood was not properly closed! Is that bad? I didn't exceed 50mph, and it should be fine. What do you guys think?
Old Mar 11, 2003 | 05:12 PM
boiler's Avatar
It's bad when it flies open and wraps itself over the top of the car. That is why there is a safety catch.
Old Mar 11, 2003 | 05:25 PM
Gernby's Avatar
Former Sponsor
As long as the car didn't overheat, you're fine. An open hood will allow more air into the engine compartment, but will reduce the amount of air flowing through the radiator.
Old Mar 11, 2003 | 05:49 PM
Randman's Avatar
Hmm, I was going to pick up my CF hood about 120 miles north, obviously the S doesnt have room for 2 hoods, so I was going to drive up without one, and install it there. Would I risk overheating the engine if I did this?
Old Mar 11, 2003 | 06:07 PM
xviper's Avatar
[QUOTE]Originally posted by Randman
[B]Hmm, I was going to pick up my CF hood about 120 miles north, obviously the S doesnt have room for 2 hoods, so I was going to drive up without one, and install it there.
Old Mar 11, 2003 | 06:20 PM
Schatten's Avatar
the electric fans, like most fans on cars, are only functional up to 35 miles an hour. after that, as long as you aren't travelling in a vaccuum, you'll be fine.
Old Mar 11, 2003 | 06:25 PM
Gernby's Avatar
Former Sponsor
[QUOTE]Originally posted by xviper
[B]
As you live in San Diego, this is a distinct possibility.
Old Mar 11, 2003 | 08:51 PM
jzr's Avatar
jzr
Don't forget the engine is pumping a whole lot more air at 9000rpm than at 4000; that takes work. Engine braking is more than just friction.
I seem to recall the folks with oil pressure and temperatire gauges indicating that their oil did not reach an ideal operating temp until a few minutes after the third coolant temp bar came on. If my car were at 2 bars steady state I'd be worried my oil was not operating at its ideal temp. This increases wear and decreases gas mileage.
Old Mar 12, 2003 | 05:41 AM
Gernby's Avatar
Former Sponsor
[QUOTE]Originally posted by jzr
[B]Don't forget the engine is pumping a whole lot more air at 9000rpm than at 4000; that takes work.
Old Mar 12, 2003 | 06:55 PM
Randman's Avatar
I am guessing I will be doing about 80 or so the whole way up, I am in a caravan, so traveling speeds go up a little bit usually. I am just hoping it will be safe to travel up there without the hood, temps in the morning out here usually wont exceed 65 I would think.
