dumb brake question
Old Dec 15, 2003 | 03:03 PM
genghiskwong's Avatar
Default dumb brake question
just want to make sure.....
will condensation on the discs cause brake squeak?
I checked my pads about 2 weeks ago and had over half left. with the weather change (yes it finally happens even down south....) my brakes will squeak when I first use them or when I lightly depress them.
just want to make sure I am not about to ruin my rotors.
thanks
Old Dec 15, 2003 | 07:08 PM
Slows2k's Avatar
They can flash rust overnight due to the humidity/condensation. Noise goes away after a few brake applications. No big deal.
Old Dec 15, 2003 | 07:55 PM
Incubus's Avatar
Humidity in New Orleans? No. There must be a different reason. J/K.
Old Dec 15, 2003 | 08:00 PM
xviper's Avatar
If your brakes are 1/2 way through their lifespan, it is entirely possible that you have picked up an accummulation of grit and dust on the pad surface. This can give you the characteristic squeaks and squealing. You biggest concern at this point is whether or not the grit is scoring your rotors (forming lines or ridges that run the whole way around the rotor). If this is the case, it is time to put on new pads (with anti squeal backing plates or anti squeal compound) and possibly look at re-surfacing the rotors before the ridges get too deep.
GravyRobber
Oct 3, 2014 04:12 PM
mikeabtin
Jul 31, 2009 10:45 PM
ggarriso
Jan 29, 2006 06:20 PM
RareWhiteS2k
Jan 6, 2006 06:19 AM
Chr-2004
Nov 24, 2003 03:12 PM
