Dust shield screws
Old Jan 16, 2008 | 08:20 AM
Boofster's Avatar
Thumbs up Dust shield screws
Is there a tool or trick to removing these? They are behind the hub so a screwdriver doesn't have enough line of sight to undo the three little screws. I tried a socket but it still doesn't fit. I have no problem cutting but the screws are still in the way.
Old Jan 16, 2008 | 08:41 AM
2poor2mod's Avatar
im not 100% sure but i think if you remove the rotor the hub has an acess hole drilled in it. You should be able to remove one screw, spin the hub and remove all until you get the dust sheild off.
Old Jan 16, 2008 | 08:46 AM
tan0116's Avatar
I thought about removing the dust shield one time on my dad's Accord when a shop cross threaded the lugs onto the wheel studs. I was able to bend the shield and sneak the new stud onto the hub luckily.
If you do plan to remove the dust shield I believe you need to press the hub out of the knuckle. Another thing you could try is what I sometimes do for the screws on the rotor to the hub. Use a 1/4" ratchet w/ a socket for a phillips bit as a short driver. However, make sure the bit seats firmly with the head as you apply torque to avoid rounding the head.
Old Jan 16, 2008 | 09:09 AM
Boofster's Avatar
Originally Posted by hecash,Jan 16 2008, 10:06 AM
Unless you are going to cut the dust shield, this is the only way you can get it off. I cut them on my prior car.
Yeah but even if you cut them with the screws on, are you going to leave the screws in there?
Old Jan 16, 2008 | 09:51 AM
tan0116's Avatar
Why do you need to remove the screws or the dust shield? Helps keep the brake dust off the ball joints.
CynicG
Feb 13, 2017 05:12 AM
nomadicS2k
Jul 11, 2011 08:03 AM
nomadicS2k
Jun 4, 2008 01:17 AM
Cubs2k
Jan 15, 2007 10:19 AM
rhodie1211
May 30, 2005 02:55 PM
