Dyno results
Old Jun 10, 2003 | 10:58 AM
HondaS2000Tuner's Avatar
Sigh (you can tell it didn't go over so well lol)...Got the results. I wanted to take a picture of the print out but due to my non membership on this site I'm not privilege to use the pic library so I'll just type out the results.
When I first went there my S ran (without any tuning)
165.4 ft/lb torque @ 5993 RPM reaching 77 mph
227.8 Hp SAE @ 8232 RPM reaching 105 mph
After 2 hours of fiddling with the Emanage and dyno specs I got (don't be dissappointed)
172.7 ft/lb torque @ 5862 RPM reaching 75 mph
246.2 Hp SAE @ 8275 RPM reaching 106 mph
Guess I lost the coffee bet lol. But I still can't believe the numbers. Why is it that UR got 294 whp on dynojet and I'm gettin no where near it?
Very dissapponting day
Tuner
Old Jun 10, 2003 | 11:08 AM
VTEC Racer's Avatar
Wow thats really low. Are you sure you dont have any boost leaks?
Old Jun 10, 2003 | 11:11 AM
I don't think so. Boost leaks such as...?
Tuner
Herez the other part.. we put
Gear ratio: 5.497
tcf: 1.00
Is that rite?
Tuner
Old Jun 10, 2003 | 11:24 AM
Although I couldn't post the dyno print out on this forum I took the liberty to upload the file to another site. Herez the link. If it doesn't work tell me I'll sit here and cry with you (I don't know how to fix it when pictures don't come up lol).
http://compressotech.tripod.com/DSCN0151.JPG
Tuner
Old Jun 10, 2003 | 11:29 AM
derryck's Avatar
It should be close... your exhaust isn't doing you any favors. If you went with a 3" exhaust you'd have it no problem.
Old Jun 10, 2003 | 01:10 PM
Guys at the shop told me the same that my exhaust isn't really helping. What kind of exhaust is good with a turbo? Can I still consider twin exhaust or is turbo just better for FI?
Tuner
Old Jun 10, 2003 | 02:05 PM
SuzukaS2K's Avatar
maybe you can switch it to the one that i got.......UR 3inch single and I also have the high flow cat as well. Ask Darryl for detail.......
I will be at the dyno on the June 19th.......I will show you the numbers that i got.
Old Jun 10, 2003 | 02:10 PM
[QUOTE]Originally posted by SuzukaS2K
[B]maybe you can switch it to the one that i got.......UR 3inch single and I also have the high flow cat as well.
Old Jun 10, 2003 | 03:05 PM
S2000_Europe's Avatar
Tuner
I have the same set up than yours (except for 4:44 final ratio y high flox cat and 98 oct fuel )
I would go to the dyno by the end of June I hope have different numbers
HKS has 2.5 inche pipe do you think that an imporment of 0.5 inches will change his number so drastically?
