dyno'd my 03 s2000
Old Sep 18, 2004 | 05:17 AM
s2kboy03's Avatar
Default dyno'd my 03 s2000
i dyno'd my 2003 s2000 23000 km on sept 11 at SNK's race dynojet in richmond, bc and did 2 runs with mods: Spoon air filter, Spoon CF airduct, T1R testpipe, T1R exhaust, T1R epower voltage stabilizer, T1R grounding kit, and street tuned VAFC...
1st run at 77.8 degrees F
max power=199.8 whp max torque=134.5 @8300 rpm
2nd run at 77.8 degrees F
max power=204.4 whp max torque=136.0 @8300 rpm
both reaching speed at 78mph and both plot #'s are corrected
from all the other s2000 i seen dyno'd here i guess i should be impressed with the #'s but in a way seems a little low from what i see online..
Old Sep 18, 2004 | 05:37 AM
nVz2000's Avatar
how much time between the runs?
-= joe =-
Old Sep 18, 2004 | 05:39 AM
s2kboy03's Avatar
around a 1-2 minutes or so...not much break times in between...but i will definitely dyno it again once i get my headers and i want to do some vafc testing to see gains or not
Old Sep 18, 2004 | 08:49 AM
Pdubb's Avatar
That's what I almost got Stock! Nice plots though.
Parker
Old Sep 18, 2004 | 09:37 AM
RaDZio's Avatar
I have MY00, the only mods I have are T1R testpipe, T1R exhaust and 4.57(they were not installed when I did the dyno)
I dynoed over 212 WHP, temp. was around 80 deg.
Old Sep 18, 2004 | 10:31 AM
S2KANDRE's Avatar
yea s2kboy03, from the dyno plots ive seen your numbers are pretty low, ive seen those numbers on stock s2000's...
Old Sep 18, 2004 | 02:50 PM
mxt_77's Avatar
Do you have a baseline dyno? If not, you should get a friend w/ a stock '03 to go up there with you and dyno on the same day. That way you can take out dyno calibration issues, and see where you really stand vs a stock car. Those numbers definitely sound low for a car w/ a test pipe. What did your air fuel ratios look like? Maybe you were running rich/lean? Also, maybe it's possible your engine was heat soaked. I found that I lost >15hp when my engine was suffering from severe heat soak.
Old Sep 18, 2004 | 03:55 PM
s2kboy03's Avatar
will have pics of plots once scanned and uploaded
well considering that there were 7 other s2000 at that dyno day and most of them got lower #'s than me 195whp-200 whp etc...there was one s2000 there that dyno'd 197 whp with mugen intake/exhaust/header and other mods done like mine also so i guess maybe its the dyno that needs calibrating or maybe its right..i dunno...also my friend dyno'd his s2000 in bellingham bone stock and got 186 whp..so maybe here in vancouver we get lower #'s who knows...well here are my plots
Old Sep 18, 2004 | 05:19 PM
S2KANDRE's Avatar
something doesnt sound right to me...
Old Sep 18, 2004 | 05:29 PM
SilverKnight's Avatar
Thats stock around stock #s but its normal, I mean MODs dont really add much to the s2k. Maybe at most 1-6hp with basic mods i/e/h etc. Dont sweat it man. good dyno.
