Easy spark plug specs question
Old Nov 15, 2002 | 07:07 PM
osu s2k's Avatar
Default Easy spark plug specs question
i just had the tsb done tonight and tomorrow i want to check to see first if they put new plugs in and second if they were properly torqued and the gap checked.
heres what i was planning on
gap aroun .043
torque to 18 ft. lbs.
dielectric grease on the coil contact and antiseize on the threads.
i did a search on the torque and everyone is says helms read 13 but 18 would be better, so ???
Old Nov 15, 2002 | 08:44 PM
DJHohum's Avatar
its supposed to be 18 ft lbs now. the dealer should have put a little sticker in your manual saying so.
Old Nov 16, 2002 | 09:13 AM
KennyS2K's Avatar
anti-seize on the threads is not a bad thing. however, all torque values are for clean and DRY fastener threads. Everything there is non-ferrous so rust, the seize cause, is not an issue. When threads are lubed they can be easily overtorqued. I sheared a wheel stud on my g/f car by oiling the threads and then torquing to the prescribed value.
Neuman04
Sep 4, 2009 08:46 PM
ph09kng
Sep 18, 2008 10:47 AM
Sideways
Apr 28, 2006 06:52 PM
yellafeva
May 23, 2004 07:39 AM
