Spark Plugs
Old Sep 4, 2009 | 03:58 PM
Neuman04's Avatar
Default Spark Plugs
I recently removed my spark plugs and i didnt have a torque wrench. I torqued them down to where i thought was good. Today I bought a wrench and found i over torqued it. I backed it out and torqued it to 23 ft lbs. Is this ok? Im worried that it will back out of the threads since it was previousl tighter? Do I have anything to worry about?
Old Sep 4, 2009 | 04:10 PM
chad86's Avatar
23 ft lbs is still pretty tight.. I think its recomended at 15 or so.. I do mine at 18.. but the rule of thumb some poeple use is finger tight plus a quarter turn... Your plugs should be ok tho..... Just check them again after 500 km or so
Old Sep 4, 2009 | 04:12 PM
Mark355's Avatar
Spark plugs to 18 ft/lbs. Coil bolts to 7.
Neuman04's Avatar
I just dont want the motor to go boom!!! I thought they increased the spec from 18 to 20 something cause the ap1's were having issues??? If I backed them out and went to 18 would that be a problem?
Old Sep 4, 2009 | 05:20 PM
FitzyS2k's Avatar
DO NOT USE A TORQUE WRENCH ON THE COIL BOLTS!!!!
they are small screws and only need to be hand tightened.
Old Sep 4, 2009 | 07:48 PM
Crisgo's Avatar
You should be just fine. I wouldnt worry
Old Sep 4, 2009 | 08:46 PM
scors2's Avatar
dont worry about a thing.23 lbs is nothing.
josserman
Aug 3, 2010 03:14 PM
scottieboy561
Oct 20, 2008 09:34 AM
ph09kng
Sep 18, 2008 10:47 AM
Sideways
Apr 28, 2006 06:52 PM
osu s2k
Nov 16, 2002 09:13 AM
